Seems like everyone that does a DP ends up with smoking issues.
Only if the issue is already there. The smoke is just not seen withe the stock cats in place.
Quick quesiton: Will a Cobb Sri, Corksport downpipe and test pipe give me around 300whp? or will i have to do an accessport as well?
so i have herd a rumor that the ms3 block can only Handel around 350 whp
dose any one no any thing abut this
330whp 342 tq sir just dynoed on stock block lets see how long it holds n this is with no boost controller stock intecooler n stock exhaust n stock fuel pump
agreed. It really has been interesting to see the higher performance tuners stay so quiet. I realize they are other forums more dedicated to the more extreme side of things. If there is a 400 whp Mazdaspeed3 I would think it would be all over the front pages. Around 300 W hp is plenty enough I would think, in this car unless you are just full on!there are so many more variables involved than 'how much HP can the block handle'
You have to take into consideration that fueling, boost, timing, EGTs, AFR, all of these things come into play.
People have blown stock blocks with less power, and some people have been fine on 380whp and NO tuning.
Nobody will know what the stock block can handle until there are some mad scientists that can reflash this ECU over and over and really push the envelope. So the real answer is, at this point it is impossible to tell what the engine can handle.
