Darksun280
- MS3
so what do you consider 'done right'?
I know meth is saving my ass plus no part throttle boost and no knock if possible but I'll allow up to 2.0 but I rarely see more then. 1.5's in 5th and 6th gear and the crazy psi I run.
so you never get into positive boost unless you go WOT?
In theory, i think that is right.Would put you over actually
so if you please. with the pump upgrade installed [no more cels], the stock injectors are big enough to run the increased volume and psi of air? thanks. I haven't got to that part yet.correct sir if at all possible. This baby turbo hits 11 psi at part throttle with easy and if your in 6th gear on this car it will hold stoic the whole time PT.....
