350 whp BAD!!!!!!
correct sir if at all possible. This baby turbo hits 11 psi at part throttle with easy and if your in 6th gear on this car it will hold stoic the whole time PT.....
so if you please. with the pump upgrade installed [no more cels], the stock injectors are big enough to run the increased volume and psi of air? thanks. I haven't got to that part yet.
