- 2017 CX9 GT AWD
Yep. The 2.5T is turning into a dud.2016-2020 is coolant and 2021 is oil. Pick your poison lol![]()
I’m loving my dud!Yep. The 2.5T is turning into a dud.
I wish I could love my dud. It's in the shop for a couple months to fix the coolant leak.I’m loving my dud!
Why is there "no fix" if the issue is only indicated in VIN BEFORE a certain date? What was done different AFTER said date to prevent this...because that sounds like "the fix", yeah?This TSB only applies to 2021 vehicles. Your 2018 CX-9 is not impacted by this in any way and that is the main reason your car does not burn oil. It most likely has nothing to do with the type of oil.
As for the 2021 models, there is no fix yet. And I would think there may not be one in the short term. I would also bet that if there are engine failures they will deal with them on a case by case basis - like they are doing with the coolant issue. Personally, I am hesitate to keep this long term and will most likely trade it in for something else within a year or two.
edmaz said it the best from post #41:Why is there "no fix" if the issue is only indicated in VIN BEFORE a certain date? What was done different AFTER said date to prevent this...because that sounds like "the fix", yeah?
Actually, Mazda is talking out of both sides of their mouth in this TSB. First they wrote: 'The root cause of this concern has not been identified yet'; but then immediately follow that up with: 'Since this issue has been reported after a valve stem seal modification, it is very likely that valve stem seal damage is causing oil to leak into the combustion chamber'.
This almost sounds like they changed their mind on what to provide for the reason, and then didn't edit out the original statement. However, it seems likely IMO the information about the stem seals is correct, and this will eventually be flagged as the root cause. I also think Mazda's real problem with this is deciding which repair to make. Same old story - do they trust their stealerships to do the significant engine repair, or are they just going to do the simpler (but probably more costly) engine swap.
Can't help wondering if Mazda is going to start to buckle under the weight of their various major engine issues - the ones we're aware of, and also what may still be yet to come.
As long as it remains a dud (like mine so far) and doesn't turn into an exploding bomb.I’m loving my dud!
This is pushing me hard to look at the Acura RDX A-spec advance. I have a test drive next week weather permitting.So back in 10/02/2021 (9456mi) when I went to the dealer to report the oil consumption, all they did was to give me lame excuse about the engine being "new" and they just changed the oil and top it off. Oil level was right above the FULL mark.
I'm @ 15056mi now, after 4 months, so I changed my oil today and the oil level is almost at the low level.
Poured in an entire 5qt jug after I installed the pre-filled oil filter.
Topped it off to avoid future low oil warnings in the next 5k miles or so.
I hope Mazda issues a solution to this oil burning issue sooner than later.
Killed a catalytic converter doing this in about 70k miles on my ws.6.From bottom hole to top hole is 1QT oil. Burning less than 1 QT in 5500 miles may seem like a lot to us but to ANY manufacturer it is not an issue and considered normal with today's low tension piston ring engines.
Would definitely be concerned about that BUT Fed emissions warranty is 8 years/80k miles in the U.S. and all manufacturers must repair under this lawKilled a catalytic converter doing this in about 70k miles on my ws.6.
At the end of the day, do what you want, but coming from someone who's gone through more cars than they should have: Make sure your car purchasing decision is made from the perspective of "running towards" something you truly want or like, not "running away" from a car that, for example, you're worried about having reliability issues with (all cars have them of course, more on that below).This is pushing me hard to look at the Acura RDX A-spec advance. I have a test drive next week weather permitting.
You're absolutely correct.At the end of the day, do what you want, but coming from someone who's gone through more cars than they should have: Make sure your car purchasing decision is made from the perspective of "running towards" something you truly want or like, not "running away" from a car that, for example, you're worried about having reliability issues with (all cars have them of course, more on that below).
I believe the RDX is a great SUV. Heck, I have a 2021 Acura TLX now (SH-AWD has been awesome this winter, btw) so my assessment of the RDX is based on my own biased opinion (my parents also have a 2016 RDX). That said, if you were to take a look at the RDX subforum over at Acurazine, you'd think everyone's rear hatch windows were exploding and that if you were to get an RDX, yours inevitably would too.
So getting back to my original point: Are you driven more by your desire to "run towards" the RDX because you really, really want one or are you more driven by the reliability concerns with the 2.5T being discussed in this thread?
Odds are most people will be fine and the issue will only affect a small number of users and hopefully be addressed before it affects more. Being Captain Obvious here, but I think we can generally agree that forums are not usually the best place to get an idea of a particular car or brand's reliability. You can get an idea, sure, but people are much more likely to go through the effort of going online, finding a forum, registering, and writing up a post to seek help and/or complain about issues than to simply say, "everything's been awesome" (though some do and I like to see it).
As for why I'm here even though I have an Acura now: I used to have a CX-9 (it was awesome) and I was just randomly stopping by and seeing how things were going, hahah. I'm keeping a close eye on the new CX-70/CX-90 due out in the next couple years and that rumored sports sedan (all with an inline 6 engine being an option, hopefully) for when my lease on the Acura ends too.
Gotcha - makes sense. Again, I agree the RDX is awesome. As of right now, I've got it on my radar if I decide to move away from a sedan when my lease is up too.You're absolutely correct.
I was into the CX5, although I was not huge on the AWD system, it is pretty good, but the RDX was just a bit more, in every way. The SH-AWD, the adjustable dampers, etc. were what pushed me. Supposedly the rear windscreen issue is fixed. That said, Acura sells 50-60K RDX's per year, and if a couple hundred have broken so far, that's still within the realm of "there was a bad batch/process" and not something I am super stressed about. The oil usage is a TSB with no resolution per Mazda. THAT is concerning. Also...rear windscreen>engine when it comes to replacement. Again though, it was the whole package, not just this one issue.
