Just out of curiosity: what's the deal with the steel rims? I learned to drive on snow ( manual transmission - long time ago) but I never knew or nobody told me anything about this. Is it better for the car to have steel rims in the winter?Winter tires are on steel rims (finally). First impressions are steering seems heavier. Glad to have these on before the snow starts really falling!
Far cheaper than alloys, bend instead of crack in cold weather (it can be hard to see curbs when there’s snow banks blocking view), and they sort of protect the brakes from snow buildup. Lots of times driving between Duluth and Houghton in 8”+ of snow I’d arrive at my destination with the inside of the wheels absolutely caked with snow. It can cause weird vibrations until cleared.Just out of curiosity: what's the deal with the steel rims? I learned to drive on snow ( manual transmission - long time ago) but I never knew or nobody told me anything about this. Is it better for the car to have steel rims in the winter?
That's something I would like to do....also the MAF and MAP sensors.Cleaned the throttle body today. Never cleaned it so I was curious to see how dirty it was. As many other people pointed, once you remove the assembly as I did, do not force the valve open, leave it the way it is or you can damage the whole assembly.
View attachment 332536View attachment 332537View attachment 332538View attachment 332539View attachment 332540View attachment 332541View attachment 332542View attachment 332543
Pirelli Scorpion AS Plus 3, good choice. On my other vehicle, i did LED's. No doubt they were bright. But at times I found it to be a little too bright depending on the conditions. On my current CX-5, I have no plans on doing LED's. I'm actually satisfied with the light output.Replaced interior lights to LED...huge difference! New tires, Pirelli Scorpion AS Plus 3.
Regarding the Pirelli's, they are asymmetrical. There's an "inside" and "outside" orientation. I didn't know that and neither did the installer. Three of the tires were mounted incorrectly. Took them back and had them redone.Pirelli Scorpion AS Plus 3, good choice. On my other vehicle, i did LED's. No doubt they were bright. But at times I found it to be a little too bright depending on the conditions. On my current CX-5, I have no plans on doing LED's. I'm actually satisfied with the light output.
Hmmmmm. I don't think I've seen anyone posting of breaking a belt on the road. What year and miles for your cx5? Does it live in extreme conditions? The next thought in my mind is that the belt itself didn't fail but rather a component that is driven by the belt failed and took out the belt.Serpentine belt broke on the freeway Wednesday evening. ...
Totally agree. I would've been screwed if the water pump belt would've failed, too. So out of caution I decided to replace the water pump belt together with the serpentine one.I do like the design of the water pump driven by it's own separate beltthat's handy for limping home (for as long as your battery lasts anyway). Good system.
I replaced the serpentine and water pump belts along with the tensioner on our 2016.5 a few months ago at about 185,000 miles on the OEM equipment. Still looked in decent shape when I pulled them off but I figured at this point, new belts would take us to 360k so might as well just change 'emMiles around 164.000, still the original belt. So it was long due. ...
I went with LEDS in all the interior lights, huge upgrade makes it feel much more premium. For the dome and map lights I have the LEDs facing inwards towards the vehicle as I found them too bright shining out.Map light bulbs -- ordered several of the LED 5000K bulbs from VLEDS, with a claimed 170 lumens. Should arrive late next week or the week after. Hopefully it'll be heads and shoulders above the anemic DE3175's currently in the car. Don't use them much, but I darned well want them bright and a warm-to-daylight quality of light.
HO SERIES WHITE LED BULB 30MM 3022 3175
#html-body [data-pb-style=IEPU1JI]{background-position:left top;background-size:cover;background-repeat:no-repeat;background-attachment:scroll;align-self:stretch}#html-body [data-pb-style=YAHLMQV]{display:flex;width:100%}#html-body [data-pb-style=L72591T]www.vleds.com
So do you have a 2.5L NA with CD or a 2.5T?Did the first oil change at 4500kms on our 2024 Akera G25.
Used a great quality Australian oil, Penrite Enviro+ 0W 20 full synthetic. Comes in a 5L container so I have a small amount left for top up’s if required.
