CX-60 Rear camera cleaning system
Thank you, Antoine - unfortunately I have no clue how to create a "Resource" - any guidance welcome...
Sure...Very similar to posting a thread...Simply click on the orange "Add resource" button at the top of the page via the link below...
CX-60/CX-80
You'll see there's an option to upload files (you should see the option, please let me know if you don't)...I would try putting all the files into a single zip file if possible...If you need further assistance, let me know and if you create it, please post a heads up here, thanks!
CX-60/CX-80
I see the "Attach files" option, but when I click it and a window for selecting a file is shown, the ZIP file is grayed out - maybe because it's too big? It is 60 MB (scanned images...)
That could be it, I increased the size on my end to 70 MB although I'm not sure if that's enough, may need a server settings change as well...Try uploading the 60 MB zip again, hopefully it works!
Oh make sure you're uploading via this option (and not the option below the description box)...
Update: Issue might actually be with zip extension not on the main allowed file extension list. Now both main and Resource lists are in sync.
> Oh make sure you're uploading via this option (and not the option below the description box)... - I'm sorry, I don't understand what that means... I just hit the "Attach files" button I see below my reply. Now the ZIP file is no longer grayed out, but after I attached it, I got the message: "The uploaded file is too large for the server to process".
No worries @Gajdzin …Here’s another screenshot below showing what I mean…Try the “Attach files” near “Type:”…Just to be clear, this is via the “Add resource” button on the CX-60/CX-80 resource page…
Let me know if that works or not…Hopefully it will…Thanks for your patience and cooperation!
Forgive my ignorance, but I don't know how to get to such screen as you show, with "Title", "Tag line", "Type", etc... All I see is this:
Thanks in advance for your help :)
@Gajdzin First of all, thanks for your patience!
Okay, the file size limit has been increased to 75 MB so you should be able to upload it successfully now…🤞
OK, so I uploaded the ZIP file and this time it didn't protest about the size :) It looks like it's uploaded, as the ZIP filename shows under "Uploaded files:"
However, when I click on "Save" I get an error message: "Oops! We run into some problems. You must upload a file or provide an external download URL."
Maybe I'm doing something wrong again...
Okay...It looks like we're not out of the woods yet with the server config...It could be that the zip file needs more time to process and it's unable to complete so it deletes it even though the file name appears...I'm working on seeing if that time can be extended...In the meantime, can you post the resource with a smaller temp zip file to see if that works?
Conversely, if possible, you could try breaking the one zip into several smaller zip files and see if that works...I'll be sure to post any updates!
SUCCESS! :)
That's great to hear...Thanks so much for sticking with this and for creating the resource! So it's likely a processing time issue (which I'm working on).
For everyone's reference, here are links to the 2 part resource:
OK, it's installed and it WORKS in European models as well, although meant for the Japanese market! The installation does involve some drilling and connecting wires inside the rear door, so unless you are a DIY guru, best left to a garage. I have the full scan of the installation manual (in Japanese) and happy to share if anyone needs. I don't have a translation, though, I translated it in real time for the mechanic who was doing the install.
The accessory can be ordered from a number of Japanese online stores, e.g. Nengun. You need both parts, the camera cleaner (C900 V6 560A) and the wiring kit (K31V V6 565).
If any questions - shoot :)
Hi, can you please share the installation guide for this kit? Thanks!
