that is correct... and it has been said many times. you cannot compare this manifold to stock at 6psi. it does not make it a good value (unless you really need the looks for show)
it shines when it is given more boost. and it has proven itself in the dyno. and it will again (I think someone will be there) at the MAM dyno day on March 12th.
the point is, skeptics need to quit trying to make this product appear as a bad value. Because it has been proven to do exactly what it was designed to do.
