dlarkin_dc
- Mazda 5 2007 Touring
Ha ha! Back on the road. Total loss write off my ass
Looks great! How did you end up handling the damage and insurance?Ha ha! Back on the road. Total loss write off my assView attachment 334696
The dialog with insurance went like this after their assesor was done...Looks great! How did you end up handling the damage and insurance?
Wow, that's some camber on the rears! Is the red chin painted on? (To match the side sill fairings)She's in dire need of a wash, but it finally warmed up enough outside for me to put in some fogs I bought last year
The red is actually just vinyl that's cut along the bottom and goes all the way around!. Here's a photo of it in the summer.Wow, that's some camber on the rears! Is the red chin painted on? (To match the side sill fairings)
Make sure you use NGK OE Laser Iridium and literally nothing else. Not even the NGK Iridium IX's are correct.Replaced the driver side control arm after finding out the ball joint was toast only 100 miles into owning this 2012 Sport edition.
Did a transmission pan/gasket/fluid overhaul since it had never been serviced and the fluid was jet black.
Changed the air filter and swapping spark plugs out tomorrow. Hopefully getting around to a brake bleed by next week and changing out winter tires for some more fuel efficient, less road noise set for summer!
So far excited about this car, but might be running into some concerning electrical issues or a phantom drain. We'll see what it's looking tomorrow after I get the battery jump started. Fingers crossed nothing major as me and my 5 are just getting acquainted.
Just curious on what radiator fluid yall recommend or use. When I installed this new radiator last year, I just used some fluid meant for Ford vehicles, since this is essentially a Ford engine.
I ain't going nowhere! I still have a 2013 CX-5 and now a 2021 CX-9 in the fleet. And I still know a good bit about my old 04 Mazda3 and 12 Mazda5!@theblooms congrats on the new CX-9!! She's a beauty!
Thanks for all your contributions to this forum, you'll be missed!
Doug
and he rode off into the sunset to be never seen again in the Mazda 5 sub forum lolI ain't going nowhere! I still have a 2013 CX-5 and now a 2021 CX-9 in the fleet. And I still know a good bit about my old 04 Mazda3 and 12 Mazda5!
For what it's worth, my other cars were a 92 323SE, a 93 Protege LX, and a 93 Ranger which was an absolute twin of the B3000. The only difference was literally the grille.
Valve cover gasket has been leaking since I got the car. Nothing major, but I noticed residue on the right side and some on the back towards the exhaust. Also was building up by the sensor on top. Funny thing I couldn't for the life of me find out what the name of the sensor is or what to even call this gasket. I had to do a lot of running around looking up pictures of Mazda 3, 5, 6 and Fords. Luckily I found some stuff to put me in the right direction. People were calling it a VVT Solenoid and others saying Oil Control Valve, but what ever it was it is Part# L362102D5A. Also the only way to install this gasket is removing the valve cover, since you have to press it in from the inside.
It's not a bad job at all. The one and only thing that SUCKS is those damned wire harness clips that go over the bolts. I do believe that Satan himself designed them.I think I'm about to have to remove my own valve cover to replace a gasket. I just changed out spark plugs yesterday (they were completely toasted) and noticed an ungodly amount of oil around the base of the ignition coils and all over the spark plugs, upon pulling them out. No indication of a head gasket leak, just oil leaking past some seal. Not looking forward to it, but seems like an easy enough fix? Mine seems to run fine, I just like addressing all the issues a vehicle has as soon as I buy it so I know what I'm working with, so new gasket it is.
If you are getting oil inside on the coil packs where they connect to the spark plugs, it probably means the valve cover gaskets around the spark plug holes is going bad. Spark Plug #2 was the one for me, when I removed the coil packs the tip was covered in some oil.I think I'm about to have to remove my own valve cover to replace a gasket. I just changed out spark plugs yesterday (they were completely toasted) and noticed an ungodly amount of oil around the base of the ignition coils and all over the spark plugs, upon pulling them out. No indication of a head gasket leak, just oil leaking past some seal. Not looking forward to it, but seems like an easy enough fix? Mine seems to run fine, I just like addressing all the issues a vehicle has as soon as I buy it so I know what I'm working with, so new gasket it is.
