Jeff@Tri-Point
Ordered my 8611-1257 Race and 8611-1259 Race with a 48x1.5 Glad Nut
The 1259 Race are really short but what I'm planning on doing is making a spacer that will fit insid ehte strut housing and raise up the insert to the right spec for the rears. I will have more info on this later.
The sport inserts will not have enough dampening but you can revalve them... Keep in mind that the race inserts will be close as far as maxing out the front rebound if you are using a 450lbs spring in the front. I think I will have to revalve mine soon but its to early to tell.
