also can the oil squirters be removed and the holes plugged???? what are the downside to this???? would a oil sump of some kind help????
Jeremy
Jeremy
You want the squirters for reliability and longevity. Did the entire squirter including the base fall out or just the tip get broken off? You should buy a new pump assembly.
I just called and asked my machinist about this and he said all was good with my motor/squirters/arias pistons(stock bore), he automatically checks this and something about keeping a clearance of 60 thou..guess he's saying thousand?
My block is a new factory assembled fs-de short block though...is this an issue or concern ONLY when your rebuilding/over boring/installing new squirters or what?
the whole base fell out...
It's impossible to BORE the pistons with the Oil Pistols installed. They interfere with the process..
If you are not getting it bored, there will not be a problem..
And for you folks who think you can just bend the oil squirters down for more clearance, I tried that, and they still got sheared off by the JE Pistons!! I have learned a lot over the years. One of the main things is spend the money, and the time to do it right to save yourself potential headache down the road!
So, I want to bring this thread back from the dead. Not the attitudes expressed in this thread, but this the facts. Now, someone correct me if I'm wrong, but it is my understanding that the first run or so of Arias pistons were not machined with an adequate oil squirter notch in them, and Sam had one set of these. Since then, this has been remedied (I've had 3 sets of Arias pistons in the last 2 years, and all 3 have had a really predominant oil notch actually.)
Now my question is this. What clearance are we looking for exactly? Back many pages, dana took a paperclip and measured the clearance to be 1.1mm. If I recall correctly, that was my engine he did that on.
And since then, I've had no problems choppping squirters in the 2 times it's been rebuilt since then. So, I put my overbore motor together last night, and I have about the same clearance. Basically, I bent the squirters (they are new btw, the block was bored 20 over) as far down as I could before they hit the crank. I'm super paranoid here, but I'm still dying to know how much clearance is enough.
Dana did that with mine, no probs.
You already have several flaws in your statement. Allow me to clear this up.
There was never an issue with the notch in the oil squirters. I sold 100 pistons with the original notches, and one of those sets of pistons were in the motor that I built for you, which didn't have clearance issues with the oil squirters.
After countless successful motor builds with no oil squirter issues with the original notch cutout, including your own motor, Sam had an issue with the squirters. It's the first FS he built, so I called it installer error while he blamed the piston.
From then on, I had ridiculously large notches cut into the skirts, as to basically idiot proof it, so that anyone could install the squirters blindfolded and still not have an issue. The upside is that it takes less time to build an engine now since you no longer have to line the squirters up properly.
That's correct. 1.1mm of clearance with the ORIGINAL notches. That's far from inadequate.
If you have 1mm of clearance you should be fine. Since you have the newer pistons with the silly cuts in them, you'll probably have much more than that. Make sure you clock the oil squirters to the right position.
Post pics if you're worried, but you should be fine.
12,000 miles and 2 synthetic oil changes later and my Arias are doing fine.
Ah...ok no need to come at with a violent hug now. (confused)Yep and you had the revised cutouts. Pictures speak for themselves.
