Vibration At Speed
propflux01
2024 CX5 Signature
Took the 5 out for a few errands, one consisting of 40-mile highway trip. On the initial freeway drive, I felt a high-frequency vibration. At first, I thought it was just I-40's usual bumps and ridges, but I noticed in my rear view mirror that everything was blurry as well. it did it between 65 and 85 mph. It was not a tire issue, as it was too high in vibration frequency, more like a driveline vibration. The wife felt it as well, with her arm on the armrest. On the way back, it did it again, then slowly went away.
Has anyone had a similar issue?
Vehicle has 27K on it, has had no issues, and just started this out of the blue. Tires have about 10K on them, and no other issue with them. Again, it was very high in frequency (for those that ride, was like when the vibration of the bike makes your motorcycle mirror useless), not any kind of tire vibration I've ever come across.
I would take the car for a steering alignment and maybe check the tire balancing.
...and tighten (just a bit not much) that rear view mirror. You dont want it to fall off.
If you check you will see its loose. Lift it lightly up/down from the frame in order to check.
