Well this is what I am thinking:Matthew said:yes, both the blue/yellow and pink/blue wire turn into a shielded gray wire and the ground is basically wrapped around the pink/blue inside the gray shielded wire and connects to the black/white wire near the harness.
so disconnect that ground or not?
what about that fuse, anyone know what its for?
what else could it be...gotta be something to do with that wire. of course, it still doesnt fix the boost problem, but its obviously a problem if i disconnect and the car idles good.
also, what about the 0v to the first o2 sensor?
That wire inside of the grey shielded wire got pinched somewhere. The black/white is just a ground. It is grounding the pink/blue wire, hence why you have 0V on you O2 sensor or close to 0V.
0V on you O2 and the car thinks you are lean, it adds more fuel.
As the RPMs go up the computer gets freaked and it is out of limits, it's saying this cannot be possible, throws a CEL and leans the car out.
