[syko.xero]
I am gonna run my 03.5 in the local autox this weekend in the "stock" class and wanted to know what would be a good tire pressure setup to run front/rear (temp in the 30s-40s
MSP Pro said:Dialed in my pressures on the stock Bridgestone RE040s this spring: F38 R35.
dolphin said:The tire pressure you run depends on a lot of things. For example, the tires, the surface you run on, the course design and how you drive. I have been autocrossing for >35 years. Lately we have been running on asphault, more open courses and I used 38-40 fr and 32-34 rear. In general if the course get tighter, I raise the rear pressure more than the front. If you look at the TireRack web site, they have a good set of instructions on when and how to change the tire pressure.
When I run on grippy concrete, the tire pressures are higher all around. This is with the stock Bridgestone 040. The Dunlop SP9K's on the MP3 took more pressure on the same surface.
You need to watch the sidewalls of the front tires and see where the scuff marks are. If they go off the tread then you need to add air. If they stay too far on the tread, then you need to lower the pressure. Once you get the front working the way you want, adjust the rear pressure to get the feel that you want.
I know that is not a single answer but it may allow you to develop your own. I hope that it helps.
dolphin said:Brian,
Since the scuff marks on the tire can stay for a long time, it is sometimes difficult to determine exactly where the tire is rolling over to on the tread. So some people use a dab of white shoe polish at several places around the tire at the very edge of the tread. This way you can more easily see where the tire is running. You can also renew it easily every run or every event as you desire. The disadvantage is that your tires now have white shoe polish until you can get it off. It is not always easy to get the shoe polish off. Does this make sense now?
dolphin said:Allen,
Did you actually cord the tires? Usually when they go that bad that abruptly, it is because they have worn through to the cord. The first set of SP9K's on the MP3 were worn as smooth as a book cover and still working great. The instant they wore through to the cord you could feel the tires go away. The second set of SP9Ks is still going strong. Of course Heather is not as aggressive as I am.
In any case, remember to have fun.
