its a stewart warner
i have the same reading as you at idle with my stewart warner gauge. if you read around, alot of people share this reading with the stewart warner gauge. i dont know what the deal is but it is a hair off.
i hooked up a vacuum gauge just to check my idle in comparison to the stewart warner, and i pulled -21 vs. -18 that my sw gauge was showing.
yea i find that odd as well. however, the boost is pretty close to my electronic boost gauge on the ebc.Thats wierd, well is boost reading right thats my main concern lol.
Once I figure out an efficient way to print the datalog (currently only prints to my printer and I would have to scan it) I will post some up. I've just started modifying the SuperMap to fit my needs. It actually was pretty good - just a tad lean at lower RPM and too rich from about 5200 RPM and up.Could people with their wb02 logging to the AFC post some of their logs? I'm trying to get an idea of how everyones fuel curve looks and when enrichment starts.
Did a quick in-thread search but it was of no help to me... I'm just wondering if the stock supermap is good for only unflashed ECUs or is it alright to use with flashed as well? Any changes that should be made to the map to use with a flashed ECU? Thanks.
Who can help me out with a map?
I have the AFC V2, mods are:
Full turbo back exhaust
Injen CAI
Corksport FMIC
Walbro Fuel Pump
440cc Injectors
18 PSI Boost
Forged Internals with 8.5:1 compression
Thunder Manifold
It's just to get me by for a while till i can get the stand alone.
please someone help me out!!!
thank you kindly
