Good evening all,
Here's an interesting one I thought I'd post to get a consensus on an engine misfire on all cylinders issue on my 2020 CX-9 GT 2.5T. 36k miles.
Yesterday, I noticed the engine running rough, lower idle than usual with the car in drive and my foot on the brake. Engine sounded wierd and was stumbling and felt like it was close to stalling. If I remove my foot from the brake, the idle went back up by at least 100 rpm and the engine smoothed out. Press again and idle lowers and engine stumbles.
This does not happen if the car is in park idling, even with foot on brake. It only happens when in drive or reverse with foot on brake.
Broke out my TopDon BT scan tool to look at live data stream and confirmed that there were many misfires on all cylinders occurring with numbers slowly rising, however NO check engine light was on or had been triggered thus far. This was confirmed over multiple trips. Incidentally, if I leave the car to cool off and come back to start it a couple hours later, the engine has trouble starting for a few seconds it cranks and stumbles and finally gets going. Almost as if there was bad plugs or coils, but that is not possible because the misfires are across all cylinders.
I looked under the engine cover and there is no damage to the wires to the coils or injectors from any animals.
Further, the plugs were replaced with genuine NGK at 30k miles as preventative maintenance even though 40k miles are the normal time to replace.
So, before I take it to the dealer(I have a mazda oem extended contract) I thought I'd post and play a game of what could be wrong and who votes the most on the multiple choice answers to the problem below.
Possible choices are:
A) Bad brake booster with torn diaphragm/vacuum leak letting unmetered air into engine causing misfires and idle fluctuations when brake pedal applied under engine load
B) Dirty or stuck EGR valve
C) Cracked Cylinder head causing coolant intrusion and misfiring in all cylinders,also causing hard starting since coolant can pool in the cylinders and is not combustible like gas.
D) One or more cylinders have low compression due to bad rings or for unknown reasons.
E) Combination of any of the above
F) None of the above.
Lets go!
