A high flow fuel pump will also help. I just ordered one because I'm going to be up around 10 psi with an upgraded turbo and I know the stock injectors and fuel pump can't handle that. I have some 440's but I'm holding off putting them in if I don't have to.
Yeah, I wasn't questioning that. I just know some people have had successful with the stock injectors and a faster flowing fuel pump. It might have been Turfburn that had the stock injectors with boost pressures up around 15-16 psi with the Walboro and didn't have any leaning out problems.The stock fuel pump seems to do fine with 440s.
Fatti03 just a question for ya, what did you do to fix your car when you couldn't connect to the conroller from your laptop??? I'm having the same problem and i'm ready to kill someone....lol
i would s*** my pants if i see 14's afr's!!
hell no!!!
i see something past 12.5 and i'm already letting go of the gas...
im local lol..but my s**** already installed andeverything and supemap is what i was running didnt know if i should change it now that i have more mods..i guess wideband should be on my list of things to get..
well if you are using a Serial to USB cable then you have to load drivers for the cable, I bought the cable from radio shack and it came with a disk. I plugged it in and it worked(i did have to use com4 BTW), but if you are using serial to serial and its not working you have to go into your comp and change the com. # not to sure how you do that but that, but i know its somewhere in the setting. If those dont work then check your power and ground cause i know i got a box saying there is no power to the ECU but that was cause i didnt have the drivers for the Cable.
Yeah i installed the driver mine was com port #4 too, well thats the only one that would even count down to try to connect...i'll check again though thanks!! Maybe that is part of my issue of connecting....but shouldn't my car at least run more than 5 seconds after the install??? I should be able to just drive away!!! I know maybe the stock supermap is not the best for my vehicle but wtf????
