I question the value of forged this and that, though. Forged pistons vs. hyper pistons are a losing proposition unless you plan on a power adder. They fit sloppier in the bores, and they are often heavier. I simply see zero gain to a forged piston unless it is necessary. It's akin to installing chassis reinforcements on your CX-5. Would it make it more rigid? SURE! But really? Is it necessary? Nah. It would just add weight and cost money.
My 2000 LS1 Camaro had hyper pistons and had notorious piston slap on cold start. The CX-5 has no piston slap.
Mazda didn't just pick a forged piston over cast. Forged pistons are stronger and so can be made thinner. Mazda designed skyactiv engines from the ground up with bleeding edge technology and I believe the entire forged lower end (pistons, rods, crank) are built lightweight. When engine braking going down mountains, I was surprised how little braking occurred due to lightweight reciprocating mass of the engine. The CX-5 engine is; tough, lightweight, and very efficient.
