tenminutes
- 2015 CX-5 Touring
If you cut or brake the gray clip holding the dash speaker cable you'll be able to pull more cable out.
Many of use (probably most) have reused the plastic frames of the old speakers. Just need a knife to cut around the edge of the cone, and a pair of wire cutters to snip the magnet support arms. When I mounted my Polks, no dremeling was necessary. See here for photos (not mine): http://www.mazdas247.com/forum/showthread.php?123829645-Speaker-picsI think I missed it somewhere in this thread, but could someone recap which wires are positive and which are negative on all the speakers?
It would be most appreciated.
Also ...Have you guys been reusing the stock plastic (baffles??), that the old speakers are in, to install your new speakers? I figure since I'm just going to trash the old crumby speakers that I would try to reuse them and mount the new Polk speakers in them. It looks like a little Dremeling is necessary but I think I can do it. I want to reuse the simplicity of the "plug and play" system that they already have .... but I'm not very confident in soldering. Although I am willing to give it a go!
Thanks.
Not quite sure if your pos/neg question is about the factory speakers, but if so, see the attached for the wire colors to the pos and neg terminals.
Does it sound like too much treble?The front ones, I have installed in the little triangular plastic piece by the mirror and the rear tweeters I have installed just in front of the window switches. I also have the Polks in the dash.
NOW .... Someone tell me about this Alpine KTP-445U Power Pack. Is it really so simple to install in the CX-5? Who's done it? An do you have any pics of the install or instructions?
Same here - ordered on from Amazon but not here yet...
Then you, sir, are the official "guinea pig"j/k
Seriously though .... when you get it, and if you install it before (or if) any one answers the question(s), please either post pics of the install or detailed instructions as well as your overall satisfaction with it.
Thanks.
Here's the interconnect spreadsheet I made when installing my Kenwood. Just see the left hand 3 columns...The main issue I anticipate with the amp is figuring out the speaker pinouts on the back of the head unit to wire into. Some other posts on this forum re: replacing the head unit should help.
http://www.mazdas247.com/forum/attachment.php?attachmentid=207000&d=1397674062
Will taking dash tweeters and runnung the wires to connect them in the d pillars tomorrow. Still looking for a pair of stock tweeters though to put back in the dash.How about running wires to the back pillars where bose has their 3 inch speakers And place polks 351s in there for the touring model without the bose system. Any input?
