I'm working on getting the two amps wired up. Now I'm purchasing the wire, distribution block, grounding block and fuse.
After I'm done with these, I will concentrate on the sub install.
One bad thing about these speakers is, that they can not be installed top mount. The top cover has an angled surface and that cover it's integrated into the speaker, it's not removable.
This way, may not fit under the factory cover and I may have to replace the factory cover with one made by me.
I have already sealed the spare wheel with a big rubber seal and I have machined the same size Aluminum cover, so all the mounting holes are covered and sealed.
I have also removed the original mounting "bolt" and I have replaced it with a regular hex head bolt, to create more room for the sub. I have added a wrench with the rest of the tools, just in case that I need to remove the spare wheel.
