Captain KRM P5 said:what makes Redline better than say, Royal Purple?
LinuxRacr said:I was testing out the boost controller knob this morning, and was turning it little by little to see the boost accually go up. When I got about 3/4 of the way around, I hit boost, and I spiked to like 13 PSI. My tires spun a little, but it felt GOOD! (eek2). My A/F ratios were still kinda safe though. Does the boost controller option accually adjust the maps as you turn the trim knob?
With the 3 bar map and the 460 injectors, you can boost up to 16 psi on 93 octane with 9.1 to 1 CR pistons.LinuxRacr said:I was testing out the boost controller knob this morning, and was turning it little by little to see the boost accually go up. When I got about 3/4 of the way around, I hit boost, and I spiked to like 13 PSI. My tires spun a little, but it felt GOOD! (eek2). My A/F ratios were still kinda safe though. Does the boost controller option accually adjust the maps as you turn the trim knob?
LinuxRacr said:. My A/F ratios were still kinda safe though.
HiBoost TS said:With the 3 bar map and the 460 injectors, you can boost up to 16 psi on 93 octane with 9.1 to 1 CR pistons.
Captain KRM P5 said:define "safe"
Captain KRM P5 said:i assume you mean on forged rods as well
The maping is done all the way to 30 psi, so as long as the fuel ratios are correct and you do not hear detonation, you are good to run as much as 15 psi safely.
Juan
LinuxRacr said:So does the knob affect the map?
LinuxRacr said:BTW, I just had another startup issue. Could not get my car started at all. I expected to have have issues like this, so this is not a total surprise. I pulled the plugs, and checked the cylinders. The plugs were not wet this time at all, and the cylinders looked relatively not wet. I guess this is just a matter of finidng the correct setting.
TurfBurn said:Safe is always relative! LOLI consider "safe" ratios to be around 11's... I consider a tuned ratio to be 12.5-12.8. But safe goes out the window if your timing isn't right.
TurfBurn said:Well you CAN do it on the stock rods... but your car WON'T last long. That is why we have the zoom zoom boom club.
TurfBurn said:Post start enrichment should only last about 4-5 seconds... I don't know what steve told you or specifically what the Haltech does but it is typically used for getting the motor to stabilize which takes a little extra fuel...
