Captain KRM P5 said:you can set the haltech to do up to 60 seconds of post start enrichment
Nifty..
TurfBurn said:Nifty..I may be half confusing that correction with a different one... the Microtech has like 3 or 4 startup correction factors... can be a bit much when you don't understand them all. Sounds like the Haltech is about the same there too.
Captain KRM P5 said:it has coolant temp correction, air temp correction, fuel temp correction, fuel pressure correction, battery correction, zero and full throttle maps, barometric correction, post start enrichment, wastegate duty cycle, idle speed control, closed loop 02 and adjustable injector trims.
i think from what i saw the air temp correction was too rich. at zero celcius for example his map adds 2.4% more fuel whereas mine adds about 1.1% more. That may not seem like a huge difference but in playing around with the unit that percentage of correction can change alot.
vindication said:WOW, tons of info for my n00bish ears. I was wondering if a tunning n00b like myself could learn to tune the car "good enough"? I might either go with the E6X,Microtech, or AEM(but that wont be for a while) and hope I wont get too deep. With someone to teach me the basics enough to learn the rest on my own would I be able to tune my car to purr like a kitten(or close), so to speak? Say about a year or so, to be able to tune during summer and winter conditions?
LinuxRacr said:After getting it started, I let the car sit for about an hour, and it wouldn't start again. Back to the maps...
MPNick said:Why not install your stock injectors for now until you get the hang of tuning the system?
Focus said:No offense guys, but these are the reasons I would shy away from a full standalone.
TurfBurn said:It's just a tune thing... that's like saying you'd shy away from the piggyback because you have to adjust fuel under boost. So you should just use a pre-programmed chip then. Sure it's more work... but you also get more power, and there is something to be said for the pride of knowing the car runs the way it does because YOU made it run that way. Patrick has had this thing a few days... it takes a little bit to get the maps setup right and then it's all set...
In the end you have more control... and more control comes with it's price.
TurfBurn said:I don't think that'll help unless someone already has a perfect startup map for stock injectors... and that won't help him learn to tune startup/idle. Tuning the regular maps and tuning startup are totally different animals... tuning startup/idle is the hardest part in my opinion at least!.
Focus said:You can get just as much power from a piggyback.
jrodhotrod said:Keep up with the sharing of information, all useful for me as I'll be trying to tune my own cold starts soon enough. Stick with it, and you'll get it figured out. If Ken can do it in Illinois with those 0 degree temps, and YP5 in Toronto can get it done, I have no doubt that this car can be made to start cleanly, just have to find the winning combo.
I am curious though, what maps did Steve tune for your timing Pat?
