Help Please!!
So I was following the How To for the EGR Clean. I didnt get to actually taking the EGR off. I was in a garage that was just not light enough, and without a trouble light or anything, I couldnt see where the bolts were.
So I couldnt get at the EGR how it said in the How To, the only difference was that I had to take of the Battery.
Well my battery light is on, and it is running like crazy bad now. It was stalling every time I clutched in, and now it wont start. It will turn over, but just stall out right away. What did I do?
EDIT-I am dumb, I forgot ot plug the MAF sensor back in...
Unhooked something? Unplugged something? Broke something? Forgot to hook something back up? Best bet is to get somewhere with enough light and see whats going on. If nothing seems out of place, take it somewhere that can find out, like a mechanic.
What exactly did you do? Did you remove the battery? Is that the only thing you did? Are you sure you didn't knock any hoses off of anything while trying to get to the bolts? Did you remove your stock airbox? If so, did you place something over the throttle body to prevent anything from falling into it?
If you removed the stock airbox, did you remember to plug everything back in?
OK!!!! HAHAHA, I am an idiot. I was in a rush putting it all back together.....
Forgot the O2 sensor and MAF plugs....oops....All better now. Thanks for the quick response. As soon as you said "If you removed the stock airbox, did you remember to plug everything back in?" Pro5x2...I thought about what I did, or didnt do in this case....hahaha
Same here. That's why I suggested checkin that first.
