Ran GREAT but had connection issues with battery that started few months before. Would not turn sometimes!
Everybody: IT'S YOUR ALTERNATOR
ME: CAN'T BE!
Of course it wasn’t! Battery was fully charged! Usually connection got loose. Scared to turn it off. First happens when I put a turn signal on! Had to chain it home! Cranks up soon as we get home. That’s the backstory!
Happened few more times but started corroding on terminals. Driving fine. I pull off from the store after getting gas. Soon as I hit the road it loses power and cuts off! Won’t jump! My dad gets there we jump it with heavy duty cables. Cranks like a champ! Won’t start. Put 15 in gas in Still cranking but no start!! Dad taps on fuel tank and it starts! Was low on oil but we put 4 QTs in today. 1st start seemed to fix everything. But 10 miles it cuts off at the light.
Noticing if I shift manually I can get her up to speed and good power on flat ground. Uphill loses power at 40 mph if Im going over that. Ran ALOT better after Oil , cleaned battery posts. New terminals, gauge says it’s running good Temp. Smells of Overheat when I parked. Motor has a tick when revving to keep from stalling! 02 sensor is bad. The CEL started blinking. No smoking. Lights are good. But oddly my interior light came back on when I parked it. Coolant seems to not be circulating correctly. Electrical issues I’m sure.
I can’t afford a lot. Will go to autozone and test it. All this happens at 1 time so maybe I’m ok! Need help!
ME: CAN'T BE!
