Wagonbacker9
- 2004 'Hoe
right, ok, try mashing the pedal down when you're already in that RPM range... I'm thinking your wastegate itself might be sticking, if its sticking in the open position you'll never build boost correctly. Also, pick up a new set of plugs. Seeing as you think the WGA replacement has helped, you might have burnt out your plugs while it was bad. I'd recommend the NGK ZFR7FS if you're running 10 psi, they're one step colder than stock...
other posibilities: MAF should be replaced, hard to diagnose without seeing/feeling..
