Bigg Tim said:Terbow--I sent his logs to Nick and we do not get an invalid port error? I get a box that it is trying to communicate to the MPI, when it should not. I have NO other ports being used in the 1 to 4 range and no conflicts. When Nick tried to view it, it played nothing so it's kinda wierd. I'll go in again and move things around, but I know it won't work because for some reason it is trying to communicate with the MPI during playback mode when it should not.
yea the invalid port thing isnt on the mpi software, well it is but its windows. so it wont travel within the datalog (for example if wicked sends me a log, i can prolly view it with no problem cause i dont get the error). if its trying to communicate with the mpi tell it to be offline before it enters the map screen. even offline mine loads the default map which i think is ok since its always done that. i think the communication with the mpi during playback is the reason when you get the invalid com port it wont work. i dont know why it would do that but it does for some reason. so when it sees the invalid port its like its not communicating with the mpi even though its not hooked up. does that make sense? it does to me but its hard to explain. so the workaround is finding an open port and then it "communicates" with the mpi even though its not really there. thats y he can probably play a log if hes hooked up to the mpi.
wicked or tim, send me one of wickeds logs and ill see if i can view it.
