Front Driver Side Clunk – Need Help
Hi everyone,
I own a 2014 Mazda CX-5 and I’ve been struggling with a persistent clunking noise coming from the front driver side, especially noticeable when going over bumps, potholes, or uneven roads.
Here's what I’ve already replaced (some parts twice):​
  • Front strut/shock absorber (replaced twice)
  • Lower control arm
  • Sway bar end link
  • Sway bar bushings
  • Wheel bearing
  • Inner and outer tie rods
Important details:​
  • All bolts were torqued using factory torque specs.
  • Suspension components were tightened with the vehicle on the ground (loaded position).
  • I also inspected the rear engine mount, and everything looks solid — no cracks or play, it seems fine.
  • All the new parts are tight, and there's no noticeable play anywhere in the suspension or steering.
Despite all this work, the clunking sound remains — only from the driver's side and only when hitting bumps. It’s starting to drive me crazy because everything seems to be done correctly.
Has anyone experienced a similar issue? I would really appreciate any advice or ideas. Thank you in advance!
