gboromsp said:You guys oughta see my map, with the turbo module turned off I still have negatives throughout the whole map, at wot i'm still holding about 10.3 on the wideband. Its time to lean it out a little more.
If you're that rich on the whole map, you may want to lower the fuel cal, that will lean the entire map out. You will have to adjust the idle area though. But if it's easier for you to do the way you are, then who cares, do it. Negative or positive numbers, they don't matter, as long as you get the fuel you need. The only real benifit to positive numbers is the lack of the minus sign you have to type in.
