ok, last couple of days in the morning my car has been acting up in the morning. when i start it, the car turns on and then immideatly shutsoff. On the second try it turns on... stays on.. but makes a weird noise for about 20-30 second ... then everything goes away. it only does that in the morning ( so i guess when the engine is cold).
Ok recently about 4 k ago, i was sitting in the car after driving for a about 20 mins, then tried to start it up but it would do similiar stuff but never turned on completely until like the 30th try, then the engine check sign came up.. it had to do something with the throttle, so the dealership replaced a throttle.
im lost and have no idea what can be causing this... if i bring it in the dealership, i have NO codes or anything because the car runs perfectly ( only acts up in the morning). i have 98.5 k on Mazda 3i 2004. i still have extended warranty until 100k but that will run out by the end of next week : (
please advise what to do with this..
Thank You
Vlad
p.s. i believe it could be the fuel injector or pump.. so it doesnt put in enough gas so it turns of. Note*: fuel pump has been replaced at about 60k.
Thank You
Vlad
