TitaniumSpd
- Mazdaspeed 6
So, recently, I've been having an issue with my power cutting out when going full (or close to full) throttle. I searched for similar issues and found a lot of people that had power cuts in the lower rpm range, around 2500rpm or so. My problem occurs higher; it cuts between about 4k to redline. When it happens, it almost feels like there is a violent shift that I'm not prepared for. The power to the wheels completely cuts for a split second, then comes right back, so I'm jolted forward, then right back from the power cut. This can happen several times before I shift to the next gear, all feeling about the same. The odd thing I've noticed is that the colder it is outside, the more prevalent the problem becomes. When it is below 20 degrees, which it has been alot here this season, the power cut can occur as soon as second gear. When it is closer to 40 degrees however, the issue usually doesn't occur until 4th or 5th gear. Lately, with the warmer weather, it hasn't occurred in about a week; but when it gets cold enough, it comes back. The car throws a CEL, usually on for about a week, then it turns itself off. It comes back on eventually, and faster if the problem comes back. A friend can read the CEL soon, but beforehand I'm trying to get some insight on what might be wrong.
I also have another question that may have something to do with it. Some piece of thick string got tangled on the drive belt while the engine was running and I was looking under the hood. While flailing about in the belt, it hooked onto a sensor and pulled it out, and eventually stalled the engine before I could cut it myself. I got the string out fine, but I don't know what the sensor is. It's the one about 4 inches below the oil cap. On my previous car, the sensor in that spot was a camshaft positioning sensor, but I'm not sure that's what this is. The thing that actually worried me is when I was putting it back in, I noticed there was oil on the prongs where you plug it into the sensor. I'm not sure if this is normal, but I remember it was the same when I replaced that plug on my old car.
Sorry for the long post, but I tried including anything I thought might be helpful. Let me know of anything else you might need to know, and thanks for any help!!!
