Started pulling the turbo, I had to drain the coolant so I can remove the hose and take the assembly out. I found my problem though. Wastegates probably work better if the actuator arm is actually hooked to something, right? The snap ring must have came loose and the arm wiggled off.
Any one know what size snap ring that is?
