- Plano, Texas, USA
The torque spec on those ATF pan bolts from Mazda is 71~97 in-lbs (5.9~8.1 ft-lbs). So 25~28 lb/ft putting out by your worn-out Milwaukee ratchet is too strong on torque for the ATF pan bolts.I dabbed a *tiny* amount of Hondabond HT at the four corners just to hold the gasket in place while I reinstall the pan. Other than that, goes on dry.
For torque, I use my Milwaukee M12 1/4" ratchet and snug them until the ratchet has given all it's got. And trust me it pretty worn out, so it's not much. Brand New it's only rated like 30 ft.lbs, so I guess I'm getting 25-28 out of it.
I do this on all my cars, nothing anywhere leaks, and no pan deformations.
Of course by using ATF pan gasket the torque requirement could be (and should be) different from the factory spec, but thread stripping on the soft aluminum transmission case could happen with the torque which is 4X higher than the designed spec.
