- 2017 CX3 AWD
There was probably a change in the range of fluctuation.Unless I'm missing something this sounds normal for every car I've ever owned.
Overall - Fantastic.Wow! That's a lot of K's! How has the car's reliability been for you overall?
Normal like in the 190s and how much higher did it go when idling? I didn't know it wasn't supposed to do that.![]()
Mine stay mostly at middle, sometime on right or left a bit. But been stable at least. Never noticed a large jump like you mentioned.Normal operating temp is about 90c. It would climb to 115c at stoplights, then drop to 90c a few seconds after taking off from a stop. Some fluctuation is normal, but this was way too much fluctuation in a much shorter time.
Thank you! 115C is about 240F so that's crazy hot. Now I know what signs to watch out for.Normal operating temp is about 90c. It would climb to 115c at stoplights, then drop to 90c a few seconds after taking off from a stop. Some fluctuation is normal, but this was way too much fluctuation in a much shorter time.
If we're going based off the coolant gauge (Or even if you are using some sort of tool to check coolant temps,) It's probably not perfectly accurate.
