Signs of a Blown Head Gasket
Worked like heck today to get the timing cover on before the weather gets bitter cold later this week. Do yourselves a favor folks and follow the instructions in order. I got a little ahead of myself and had to re-do the timing chain three times! Here's the order:
1. line up the sprockets
2. put the chain on, it's going to hang off the crank sprocket, I used a zip-tie just above the sprocket to keep everything in place.
3. Install the guide on the right side, the straight-ish one.
4. Install the left, curved guide
5. Install the plunger, tensioner
6. Pull the pin on the tensioner
Hope this helps someone in the future.
I paid about $750 to have 2 Ford heads (2 valve per cylinder) cleaned, valve job and surfaced, so $530 is right in line with that since you have same total number of valves and arguably a bit more complicated head design.
Thank you so much for the pictures and status updates. Reading this whole thread is making me feel completely lazy putting off a transmission fluid and filter change on the truck.
Well you can be SUPER lazy like me and never change the transmission fluid! lol. 316K miles on this CX-5 and never had a fluid change. Yes, I'm knocking on all of the wood in my house!
Ha! So there all you "change trans fluid every 30k miles" folks. Look! 316k on factory fill 😮 and hasn't blown up haha.
Well to be 100% honest, we bought the car used at 22K miles but yeah, I'm pretty sure it's still the factory fill. I know I've never changed it. And my wife is a tough driver. She does not baby anything! As far as I can tell it is still working perfectly! Getting around 30 mpg , and is still snappy.
