I’m lazy and just Googled “P0017 code Mazda CX-5” and here’s the result from its “AI Overview”:Well, it was a fun run, but I might be at the end of this project. I got everything buttoned up today and started her up for the first time. Well, I cranked it a while with the fuel pump disabled first to build some oil pressure. Then I started it up. After a bunch of initial racket and rough running, the engine smoothed out and settled down. Happy to say I have no leaks, VERY unhappy to say that I do have errors. First I got a P0031, but found that I hadn't fully seated the O2 sensor, so I plugged it in fully. But my heart really dropped when I saw I also have a P0017 error which indicates timing is off, and I still show a P0304, which is what started me down this path.
I REALLY don't want to pull the front cover off again! I swear I checked the timing chain MULTIPLE times and all of the marks were lined up right with the case, and the marked links in the chain. I even took pictures to prove it to myself. I wonder if the VVT isn't working right. Anyone know how to test the VVT?
I'm also not sure if the P0304 was left in the ECU from before I started this project? (fingers crossed) The only thing left that could cause the miss-fires is just a worn out cylinder and rings. And I just don't think I have it in me to pull this engine and do the whole thing top to bottom. For what it would cost, I'd be better off getting a used engine with a warranty for around $2000.
If I could get the timing sorted,
Feeling pretty defeated...
The last thing I did to the engine to try and help it was put a can of "Restore" in it to try and restore some of it's lost compression on cylinders 3 and 4. I'm not willing to sink more money in the engine with 314k miles. So I hope this helps. Otherwise it's going to get driven around town until it dies. I'll do a compression test today or tomorrow to see if the magic ooze did its magic.
Yes, but you want to make sure it stays reasonably high.I have replaced the injector on 4. And I hope the goo is increasing compression. Compression is compression, right? 150 PSI should still be plenty to have good ignition.
Interesting. Can you elaborate? What does the heat gun do that the regular temperature of the engine bay not do? and would it be pointed at the coil? With the intake in place you can't access the injector.Heat gun on #4 will tell if its firing.
Forgive me for not reading the whole thread from beginning but were the coils , plugs and injectors OEM? If coils aren't, have you swapped #4 coil with other cylinder that's not misfiring.Interesting. Can you elaborate? What does the heat gun do that the regular temperature of the engine bay not do? and would it be pointed at the coil? With the intake in place you can't access the injector.
Or do you mean one of those laser temperature guns? I know the cylinder is firing some times. It's just also detecting misfires, and the plug is darker than the others.
Coils, plugs and injector have all been replaced and swapped on #4Forgive me for not reading the whole thread from beginning but were the coils , plugs and injectors OEM? If coils aren't, have you swapped #4 coil with other cylinder that's not misfiring.
Yeah, it took me a minute but I figured out what you meant. Thanks, but that's nearly impossible to remove the heat shield that is on top of the exhaust manifold and get a heat gun in there accurately with everything in place. I'll consider it, but I'm fairly confident that the cylinder is firing, just misfiring.Oops, infared heat sensing gun. If you can take reading on the exhaust side of the head. They all should be close to the same temperature at idle...
