I suggest you do your own test and determine for yourself. You seem to be looking for more power from bolt on parts. Here is a cheap 10 to 15 HP.
When we use to race in a class, we were looking for every HP and stumbled on to this. It was worth a few hundredths of a second in the 1/4..
Investing in a OBD2 Bluetooth transmitter so that you can log data to your phone will be handy to check future mods and confirm or not confirm the above.
If you have to find dozens of examples, then this is not for you.
I've attached a ground to the throttle body and picked up the same amount. You might find enough folks doing it this way to venture out and try this.
A small leap of faith is required...
