I guided a friend how to ground his 176,000 mile Camery. Here is what he said:
"Was able to install another ground on the Camry. Let me tell you! It idles way better, holds constant at 13.5-14 volts at idle. Increased throttle response. Ac works way better. Car seems way happier. Windows roll up easier, everything is just happier and working easier. Thank you for the recommendation! I just did the head to the body ground. I will drive it like this and probably add another ground after a few weeks to compare"
