From what I've heard if you really want a CAI, the Injen pipe might be better because it is either 2.5" or 2.75" pipe. A 3" pipe, in my opinion, is to big to get good usable power.
I've read that a 2.25" pipe gives you good torque down low and some real power down low, but as you hit the higher end of the rpm range it tapers off more towards stock. So, it makes power, but a little to low.
A 2.5" pipe makes good power from mid to high and is a good comprimise between a 3" pipe and 2.25".
A 3" pipe makes all it's power at the top, where it isn't as readibly usable as the 2.5". If the Injen is 2.75", then it'll be a good set-up for high end usable power (that would be my guess).
As for the AEM, they make good stuff, but they say they only offer what's best for the car, and then half the Hondas and Acuras have both the short ram and CAI. Some of those options are highlighted as to which is better, but most of them aren't. So, I wonder if the AEM really is the best option for our car. However, from what it sounds like, the AEM is practically a CAI, only instead of getting air from that hole in the engine compartment in the fender and moving the overflow resivoir, it sucks the air from just above the platsic under-body thing.
Who knows? Like freekwonder said, test them all, and let the dyno sort 'em out.
[ 10-16-2001: Message edited by: ChrisS ]
