Tint question
arkitek
Possibly picking up my MSP this weekend. First mod is a tint for sure. So some questions:
Are there different types of regular tint films? What's a good brand?
Just want the reguluar stuff, no gradual/reflective/anything like that.
Any good place to go in Toronto for one?
Any good web resouces for info?
Many thanks.
Many thanks.
There are two main types, dye and metalic. You want the metalic. Dye is alot cheaper but it will end up fading, peeling and bubbling. Metalic has a lifetime warranty against those.
Good brands are FormulaOne and lumar. There are some others that I can't remember right now.
Goto FX Auto in Markham. They have a discount for Toronto Protege club members www.toprotege.com. $250 will get you Formula One Premier tint and excellent installation with lifetime warranty. Stay away from Tint King and TintMaster. FX Auto does tons of proteges and they have been just great. I beleive they have a website, just do a search on it.
Thanks for the info hawkwind101.
I called one of the place and was told that the metallic tint film will interfere with our radio reception since the antenna is imbedded in the rear window.
Anyone had this problem?!
And is the dye film as bad as you make it out to be since I might end up with it due to the possible radio interference?
Found this with a search but still kinda inconclusive....
http://www.protegemp3.com/vbb225/showthread.php?s=&threadid=13928&highlight=radio+tint
I installed metallic tint on my MSP with no radio interference. The only thing I would warn you about is that our glass has a slight green factory tint and will give you a slightly green mirrored look. That is the only thing I wasn't too pleased about. I used 35% Madico tint.
Good luck:D
The tint shouldn't interfere with your reception. I believe there are alot of people with MSP that got metalic tint and have no problems. I am sure someone will clarify this.
Have you ever come across a car that had purple windows or part of the window peeling? This is what the dye tint does after a few years. It really is that bad. Spend the extra $50-75 and get the metallic, you will be thankful you did. Plus it is better with heat reduction in summer and reducing glare. The worst part with dye tint is when it does start to peel and you get it taken off, 70% of the time it will destroy your defrost lines on your rear window. Thats big bucks to get the window replaced or the lines fixed.
Good luck:D
Is that mirror tint you got or just black? I can't see having a slight green factory tint would make the tint look mirrored using black tint. In fact I have seen alot of pics of MSP's with black tint and they didn't come out mirrored.
Yeah it looks like they got a slightly mirrored metallic tint to me. This would explain the green hue. It could also be that the tint hasn't completely cured yet when the picture was taken. Also if the shop used a green dish soap as a slip solution, this could cause a slight green hue until the window dries.
No, the picture is from today and the tint is curred, about 2 months old. The solution the shop used was clear and the shop gave me a sample of the same film and it was not green hued. Its just our windows. I was kind of disapointed with the results. If I do it again, I would not use the mirrored film.:(
Yeah, now that I think about it, when the sun hits my windows at certain angles, there is a slight green hue to it. When I installed my film, the green became less pronounced after a few weeks. Maybe the mirroring is just making the green a little more pronounced, because mine usually isn't that noticeable. But that's definitely good info for people wanting mirrored film on their cars. :)
There is a slight yellow hue to mine :-)
MSP-4-ME...I think your windows look great. Do you not get hassled by cops with that tint?? Always heard cops don't like mirrored tint. Looks good.
in CA, the law is that you can have whatever tint you want on the rear windows, and nothing on the fronts :rolleyes: anyone know what the fines are for tint on the fronts?
I have 5% on mine- Illegal as hell, but nice!
I did ge pulled once. All I received was a warning and a request to remove it. No big deal! BTW Looks like y Black Mica MSP has no windows, it is just completely black!
:cool:
in california the back can be as dark as u want as long as u have 2 outside mirrors. the front is not supposed to have any tint but a uv coating (its not worth it) and mirrored tint is 100% illegal here.. another thing i have been seeing is alot of people tinting their moonroof (sunroof?) i dont believe this is a godo idea because the way the heat will build up on it.. but to each his own. =-)
i am getting 80/20 tint... it looks nice and should keep the man off my back, the shop that is doing my windows also does custom vinyl so i am getting a " T " (think: university of tennessee) that will be color matched to our paint on the lower passenger side of the windshield. will post pics...
I got pulled over for front window tint in Cali, and it was just a $10 fix-it ticket...Not too bad, but I put the tint right back on so it cost me an extra $60 right there. I have it on my Civic and haven't been hasseled yet...I guess it just depends on how bad they wanna write you up...I was pulled over for the tint at 2:30 AM so that was all the reason they needed...
