One thing to note for anyone reading this thread...the first oil change should be EXTREMELY early. Before 2000 miles is heavily recommended, with the majority of critics/experts saying that a 1,000 mile oil change is best. (Miles on the odometer)
The amount of wear metals in the first 1000 miles is greater then 10,000 miles of wear later in the car's life, and many of these metals are not caught by the oil filter (too small), and go flinging around the engine, causing a cascading wear effect.
UOA's done on factory fill oil changes, done at a factory interval (like 5 or 7.5k, or even 10k for some luxury cars) usually show
10-20 TIMES more wear then an average oil change.
Change your oil early, get those wear metals outta the engine. Your car will thank you. Motorcraft 5w-20 Semi-Syn (stock fill) is 1.40/qt at wallmart.
(Note: You should technically change your filter at this time as well)
Always remember that manufacturer recommendations are for THEM, not for you. Your own interval's can only be found by performing UOA's, based on your driving habits, conditions, and environment. (UOA = Used Oil Analysis)
http://www.bobistheguy.com
http://www.blackstone-labs.com
The last thing the manufacturer (and especially the dealer) wants, is for your car to last 300,000 miles
