- 2023 CX5 turbo
I do my own oil changes and I only use Pennzoil ultra platnium...1 extra qt actually does 3 oil changes. Also if you use Pennzoil they will warranty your engine for 750,000 or 20 years..Not sure what’s more impressive: the synthetic engine looking that much cleaner than the conventional, or that two Ford engines ran 500k miles with only a couple failures
I’d buy cheap synthetic 5w-30 and ask the service department of your choice to use that. Castrol Edge was like $25 at Walmart today for 5 quarts. Pick up that plus a 1 quart bottle to satisfy the turbos slightly higher capacity and you’re golden (I use that one quart bottle across two oil changes). The latest synthetic certification had turbos in mind due to their increasing popularity for fuel efficiency gains when coupled with smaller displacement engines.
Warranty Program- Lubrication Limited Warranty | Pennzoil®
Check out the Pennzoil up to 15-Year/500,000-Mile Lubrication Limited Warranty that is FREE with the purchase of any Pennzoil motor oil.
