Question about exhaust
mazdaspeedpower
Contributor
2003.5 Titanium MSP
Ok, if I where to get a custom exhaust done for myself, what diameter would you suggest? I will be looking for a place locally that will mandrel bend instead of weld or crush bending. I haven't decided wheather I will put a new high flow cat or just eliminate it and just go straight back to the muffler....if I did that, I'd make sure I kept the stock, and made sure it was easy enough to reinstall for any emissions and s***. Keep in mind I will not be going too crazy with power, I'm just looking for something larger than stock that will work well with the car. I don't need anything crazy, but whats a reasonable size for a slightly modded MSP. Stock boost to slightly higher(lower than 10psi) with IC/Hardpipes/CAI
Also, what muffler would you recomend for the best performance/sound. I don't want anything ricey sounding, but I mean, if it performs better than a deep sounding one who cares. Performance over sound. Please give suggestions and input and s***. Also links would be great too, thank you.
2.5" piping will be more than enough. as for the muffler....check out the exhaust thread. you're sure to find something you like. as for performance, i believe turbo performance magazine published an article a year or so ago comparing different exhaust setups on a wrx....apexi, 5zigen, blitz, hks, tanabe, etc. the range in hp was maybe 4-5 hp. nothing that's gonna make a big difference.
the article is here: http://www.turbomagazine.com/tech/0212tur_exhaust/
i used it mainly to judge how loud my exhaust was gonna be.
jeffmsp said:
I got a 3" catback and felt no gains. Then I added a 2.5" downpipe and highflow cat and it goes pretty good. I am using the stock MSP axleback, so it is not much louder than stock. If you are looking for some more "technical" explanations, check out this link: http://www.msprotege.com/forum/showthread.php?t=67805
Would using the stock cat back be much worse than using just the stock axle back with a 2.5" down (s and j) and mid pipe? Or would it be beneficial to run 2.5" piping to the axle back?
shaun
It really epends what you are looking for. Performance wise anything mandrel bent and bigger will be better. As for the sound, I personaly havent heard a bad sounding turbo car of any kind with a performance exhaust. They just sound deep. I'd go 3" if possible, I've got 3" with a strait through muffler from the cat and it still seems to quiet for me. Soon I'll have the cs down pipe hopefully it will add some sound. Good luck.
Bob/orng1
I had a custom exhaust done and it made a big difference. I have a 2.5 inch manderal bent from the spring bolts back. Had the new arvin meritor seamless / stainless high flow cat installed (No CEL's in 2500 miles) and a standard Magnaflow Muffler. Sounds good and deep. Not ricey at all. I am actually getting about 2mpg better when I am not driving hard.
for the power you're talking about a 2.5 will be plenty for what you need
just make sure you get that downpipe changed out
For the bang for the buck do a 2.5 inch pipe from the J-pipe to the stock racing beat muffler, catless. Makre sure to get a spark plug non fouler.
Sounds good, relatively low in cost, good power gains.
are you suggesting I keep the stock muffler, and go with an exhaust without a cat? I kinda don't want get too much heat for no cat, cause I know the cops here can and will arrest you for not having a cat on the car...thats kinda why I wanted to keep a highflow cat. I know the cat is what kills the power the most, but I kinda wanta remain kinda legal. Also, how will the stock exhaust sound? I know my main goal is power, but will the stock exhaust sound ok/good....as important as the power is, I do wanna sound more aggressive than stock also.
Thanks for the help people, keep it coming.
stick a 2.5 hi flow then. same setup. works fine, makes power, and sounds good.
A j-pipe back 2.5 inch mandrel bend no resonator and 1 cat to the stock muffler will be sufficient for what you require.
Good thread here. So if I want it as quiet as possible, just add a resonator pipe then.
What is the stockpipe size cat-back anyway?
How about keeping everything stock from cat-back and just replacing downpipe, hiflow cat? Might try this first to see.
So what is the ID of the the stock muffler inlet? And is the cat back 2.5"? I though I read that somewhere.
thank you for your help.:D.
EDIT* Upon some further research, what I'd be looking at doing is a midpipe with highflow cat and a downpipe. all of which bolts right up to the stock catback. This seems to be what gives the most gain, as I already knew changing the catback really gives no gains, just changes the sound. I guess I'll go 2.5", as it seems to be a good size. I'll update you when things happen(a few weeks), with some pics and s***.
ok, so tomorow I'm gonna visit a few shops, and check some pricing and such. Hopefully I'll be able to get a downpipe to stock muffler at 2.5inches for a reasonable price. what is the diameter of the stock muffler inlet and outlet?
but wouldn't mating a 2.5 to a 2.25 be kinda pointless? Wouldn't I just be pushing the restriction further up the line, still restricting the flow, just further from the source.
bingo. granted with what you'll be replacing takes out most of the restriction in the exhaust system, if you want the best gains, go with a consistent size piping throughout.
