Exhaust Depot
Thats a wierd setup. If the ECU shuts down the injectors when you let off the throttle, then how does it idle if the injectors are off?
Or did you mean that the ecu shuts down the injector momentarily when it senses that the throttle closed?
IF this is the case, im wondering if the afc etc will work with the off throttle setup?
Hmm?
Hmm?
