Problem with Air Conditioning...Suggestions?
Hi all,
I am a new member to the forum and have a problem with my AC. The car is a 2015 CX5 diesel. Due to a hot summer with no air-con I have had the following repair work carried out;
New compressor, low pressure sensor and dryer fitted. System was flushed out and refilled to manufacturer's spec.
With blowers on full, engine running, windows up AC on and temp set to lowest setting, the ac comes on for a few seconds then switches off well before the cabin has cooled to correct temperature, also I have looked and the fan does not operate even after idling for 10 minutes. All suggestions will be welcomed.
Many thanks!
Missing info is what does your repair shop say about the issue?
Would recommend to change the AC repairman.
Possible you got a big leak or yes could be wiring/electrical but a good repairman can digure it out easily. Fan (engine) not turning suggests the compressor doesnr start.
Its bit excessive they asked you to change so many things and they dont seem to have a clue whats the root cause.
