Little Beavis said:Cool. ..8 psi. . .no lean spots? Works like a champ?
So far so good, just a tad rich (mid 11's)
So, what about my question on determining load based upon the MAF. You can do it right? Why wouldn't you be able to do this.
Quite possibly. SO LONG AS the piggy gets the proper signal BEFORE it is clamped. I don't know if it "bottoms out" too early though.
Obviously given the ideal gas law, you have a known pressure, volume, and temperature. . .then you know how much air is coming in, which means you know how much fuel to add. . .and you know THE LOAD.
Sort of. I mean, redline OFF of boost at half throttle may have the same amount of air flow as full boost @ WOT @ 3500rpm, no? See where I'm going here? Dunno if it really works like that or not.
