- 2002 BJFW, 2007 BK3P, 1979 SA22C, 2005 BK3P
yeah man if you happen to find someone to do up some rear axles for you, don't forget to post WHO and for how much.......
drive shaft shop will make a set. expect to pay about $600 for a pair.
I don't know about broken........ I remember your other thread and P5freek said that when he got his wastegate he had it tested and found out it was set to what.......23 psi? and he had to have it tuned down or whatever?
Seems like ATP is tuning the wastegates in a way that registers 18 psi for them, but 20+ psi when it's actually on the car?
....... if your wastegate was defective from factory can you get it tested and possibly have ATP either
1. pay for your engine
or at least
2. have them develop a better way of testing the wastegates if it turns out your wastegate is fine, but actually set at a high psi?
oh wow, i love this guy (cabpatch)the rear differential i believe is the same or a revision of the one in the mazdaspeed protege, mazdaspeed miata and mazda rx-8. a replacement that is stronger should be easy to find or have made.
You can check your WGA with a Vacuum/hand pump. I did this with both of mine cause I didn't know what they were set at?
i pray that you are right!!
edit: but i still think there should be a diff mount, for the ppl that don't need to replace the whole diff i.e. stock or near stock ms6's.
oh absolutely koenig, i would definitely replace my rear diff completely cuz as you all know i am a drifter . but i don't think the axles need replaced, as they are only handling 50% of the engines torque at maximum.
on a 500hp MS6, we'll say roughly 500ft/lbs as well. the rear axles will only ever see 250ft/lbs of power. the axles should easily be able to withstand that amount of power IMO.
My driver's side cv joint (part of the axle) broke shifting from 2nd to 3rd gear (not launching the car, just accelerating onto the freeway). I have under 300whp so I would say the axle IS a weak link.
men 5k for that dammm, okay cristamass is coming. by next year i shall have this block and a gt 3076r and ill be in the 11's even if i need a new tranny per pass! i jus need the goodies....not afraid of pushing the limits!
keep in mind we go with brand new blocks and crankshafts to start with. even if there were used cores available it would be damn near foolish to skimp and use them considering what is going into these engines.
Does that mean you're using the cosworth blocks and crankshafts that I see for sale on the street unit website?
