- '04 RX8
mspeedP5 said:Bump for a base 550 map.
$49.99
DeadGeneration said:$49.99
you've got a wideband?mspeedP5 said:Thanks for the offer but all I really want is a map...![]()
LordWorm said:you've got a wideband?
get out there and make your own map
"base" maps are only going to be good for getting you started - period.
A base map is not going to be something you are going to want to roll around on all day every day.
but noone's got one, or willing to share, so you may have to develop your own, or pay Steve for a base map to use.mspeedP5 said:That's what I'm looking for. A base map for 550 injectors. To get me started.
kicker22705 said:I lost my dynotuned map while trying to save it on my adapter on MemCal3 and instead loaded a blank MemCal3 overwriting my unsaved dynotuned map
i'm using the base 550cc map and now i'm getting a lot of pinging now.
i tried to tune it last night by pulling timing in timtrm to 0, timmax to 16, pulled eventually an addition 10 degrees per boost in tmap and t-rpm and although it got better, i still was getting a lot of audible pinging. i ended up jus loading back the basemap again and drove home.
LordWorm said:but noone's got one, or willing to share, so you may have to develop your own...
LinuxRacr said:Post your Microtech Maps here.
TurfBurn said:I'm really sorry to have to hold the company line of not providing our base maps to someone who didn't buy from us, but we have to be careful to protect our market and the knowledge that we've spent many hours and plenty of dyno and other dollars to gain... but that said... the map that comes on the microtech is not horribly far off to be able to start the car with 550's... I can tell you this much:
pre-Startup/cranking at ~70-80F should fall around 5.4-7.2 ms Idle when warmed will be about 1.19-1.30 ms output on the injectors (cold I believe it is around 1.85-1.92ms). Those values should get you close enough to get the car fired up. Just view the "output" box on the Microtech software in the lower right screen. Simply adjust the MixTrim value or the water temp values for your map to compensate. Otherwise, if you are already tuned on 280cc injectors. You can set the MixTrim to I believe roughly 75% positive and that will pull you in close enough to get started, but probably still run you significantly lean. However, I think the Microtech may limit to a maximum of 50% positive mixtrim.
Work toward those base injector values for cranking and idle and you'll be fine.
TurfBurn said:I take it you don't have a wideband or something? What injectors are you running? I"m guessing you are running 440's off of a 550 map? If so, you need to push your mixtrim up to 20% to even that out. Also, your timmax at 16 is WAY wrong I"m amazed the car is even running. That TimMax needs to be no lower than 28, but untuned no higher than about 34. You should be pulling also at maximum about 3 degrees of timing per psi of boost. What you've done right now is try to get the car to run at spark at TDC and that is probably causing all havoc and the car probably bucks and staggers and barely drives. So make a few adjustments to take care of it. But the biggest thing is you need a wideband on there, or at the least a narrowband and make sure the thing stays over into the rich side at all times until you can get the tune better or get a wideband. Shoot me an email at sales@nsnmotorsports.com if you have more questions past what I addressed above.
it is the point man, but don't take it too baddly when people, for whatever reason, chose not to help you out.mspeedP5 said:Go figure eh? I thought that was the whole point of this thread...
LordWorm said:...steve's given you a bunch of good starting points....
