ctt 1982 said:my a/c stops working with the fan @ 3...
Yeah mine did something like that, it is a "common" problem. Is that what you are experiencing lordworm? Try switching the fan levels and see if it will start working.
Clutch is fine..i can "override" the relay by shorting the AC Relay out and it works fine....TurfBurn said:haven't really heard of much in the way of AC problems before. Have you checked that clutch wire etc to make sure that is all intact?
If you go on protege5.ugly.net and look at the manual there is a page in the control systems section that shows the relation chart and it'll show you which sensors etc effect the AC. If anything I believe the TPS may be your culprit.
TurfBurn said:There is a pin on the ECU that you can wire the AC condenser fan to come on based off the Microtech just like the main fan. It should be called out on the last page of your instructions packet.
I actually have my fans both wired to come on with the ignition and run non-stop. A little worse for alternator load, but the improvement in cooling is considerable.
options and pump settings are the biggest b!tch with the ecu....mazdaspeedwerx said:when Iturn my ac the car dies. I need to get my car to steve to have it tuned right. the guy I took it to never saw this ems and it took him awhile to get around in the options menu
TurfBurn said:Mark, If you bought your Microtech through me or Ken it should have at least one 550 map on your laptop adapter.
i've got dyno time booked for tuesday, if the cam install goes according to plan. i bet you'll beat me by 100![]()
Sounds like a plan... I have a date with the dyno on Saturday. Any tips? I'm hoping it goes as straightforward as it is in my mind![]()
it seems a little weird that it shows your boost drop to 4 from 10 earlier while your still wot and then rise again to 10.
