Evan get rid of that thing it makes you looks like your driving a truck Good Buddy!
I'm going to swap your steering wheel out for an extremely large truck wheel at night one day.
After a week, I like the shifter extension. It's closer to the wheel so my paws are back on the wheel faster. Jake installed a Matt Damond shifter plate and I put on a JBR counterweight. JBR bushings might be in order soon. I do feel a bit like a truck driver though, haha. And no worries, Marlon. This was an impulse buy. haha
I understand that. Keeping the height the same, shortening the angle, you get a shorter throw.
But as you add height you are negating some of the % of the shorter throw as you are making the travel longer.
So my argument is that you can keep the stock setup, just replace the bushings for a better feel (stock rubber is way too soft).
Evan, I'll have to play with your stick next time I see you... And you can play with mine.![]()
I like the height of the shifter and have gotten used to it. The only issue I foresee is I had my shifter pop out of 2nd under hard braking twice last season at auto-x. However, my short shifter plate wasn't installed correctly (ahem, Jake) so hopefully that fixed it. But with the taller shift lever it might want to pop out again this season. Guess we'll see.
Wording parts for spring, yo.
OEM A/C delete pulley and belt, OEM spin on filter swap and sammich plate (still need to order the Innovate oil pressure/temp gauge from CR3 soon). CX Racing front mount, Kozmic EGR block off plate, and Matt Damond power steering cooler kit.
dsc off even for the icy roads?! dang. That thing saved my @ss the first winter I had the car. My fault for not changing the tires though.
Oh, and that's a cute color. What's the alert color on that thing? Can't think of anything more manly than that.![]()
