Natey said:looks good to me.Once the car is on the ground, the ends of the bar will raise up to about the heighth of the wheel hub, right?
viVid said:Looks ok to me too... have you checked to see if it has been hitting anywhere (marks, etc.)?
Natey said:Wai a minute. It looks as if the endlinks are on the wrong side of the(I'm not sure what that part is called) suspension. Here's a pic of mine. See how my endlinks are on the opposite side? When the car is lowered onto the ground, the endlink looks like it'll contact the suspension and possibly...break something.![]()
viVid said:Natey, you have the fully adjustable AWR like I do. h4tor1 has a 2-way adjustable and is using the stiffer setting. If you were to adjust yours back to where his is, you would need to be on the other side of the suspension as well.
Mike R said:Actually I think it plastic, nylon...but it's nice. That's what I've got. I think there is a plastic insert in the hiem joint also that makes them better and last longer.
KYREDP5 said:Ok, related question. I just installed new lowering springs, and now my end-links are knocking on my trailing links(?). Will the AWR endlinks work with the stock sway bar, and fix my problem? If not if I get the 19mm sway bar and new links will that fix my knocking?
KYREDP5 said:Well that just gives me an excuse to get a new sway bar. After taking a closer look it's actually the ends of the sway bar (where the endlinks connect) that is hitting the rear trailing arm. I'm asuming that a new bar will help this still?
h4tor1 said:Finally, no more clunking. Save by the "Magic Rubber" from Tony at AWR
Took me a while to figure about the reverse thread of the endlinks. After that, everything is simple. It is so amazing how the rubber can fix the clunking noise. The old style endlinks also have the same thing, except it is made from metal. The new style is made from rubber. I think there is only the difference.
Just want to share with you guys. If someone has the same problem with the AWR adjustable endlinks, contact Tony at AWR to get the "magic rubber". Problem solves !!!
