How easy is DIY for the spark plugs?
there's no "special spark plug socket"... it's just a 14mm spark plug socket... 14mm spark plugs are very common these days across different brands... it's just something new, that's all
Sure there is. They come with a section if high density foam in them to hold onto the plug while you carefully get the threads started so that you don't have to use a piece of hose. (Although a piece of hose and normal socket will work too!)
